Открывая новую тему в этом разделе ОБЯЗАТЕЛЬНО в начале темы указывайте код ошибки.
without the EGR system (before 2002).ISX Fault Code List
111 Electronic Control Module (ECM Microprocessor
115 Camshaft Engine Position Sensor Circuit
121 Crankshaft Engine Position Sensor Circuit
122 Intake Manifold Pressure Sensor Circuit
123 Intake Manifold Pressure Sensor Circuit
131 Accelerator Position Sensor Circuit
132 Accelerator Position Sensor Circuit
133 Remote Throttle Position Sensor Circuit
134 Remote Throttle Position Sensor Circuit
135 Oil Pressure Sensor Circuit
141 Oil Pressure Sensor Circuit
143 Oil Pressure Sensor Circuit
144 Coolant Temperature Sensor Circuit
145 Coolant Temperature Sensor Circuit
147 Frequency Throttle Circuit
148 Frequency Throttle Circuit
153 Intake Manifold Temperature Sensor Circuit
154 Intake Manifold Temperature Sensor Circuit
187 Sensor Voltage Supply
198 ICON™ Lamp Circuit
199 ICON™ Lamp Circuit
212 Oil Temperature Sensor Circuit
213 Oil Temperature Sensor Circuit
216 Wet Tank Pressure Sensor Circuit
217 Wet Tank Pressure Sensor Circuit
218 Wet Tank Pressure Sensor Circuit
221 Ambient Air Pressure Sensor Circuit
222 Ambient Air Pressure Sensor Circuit
223 Burn Valve Solenoid
227 Sensor Voltage Supply
234 Engine Overspeed
235 Engine Coolant Level - Engine Protection
241 Vehicle Speed Sensor Circuit
242 Vehicle Speed Sensor Circuit
245 Engine Fan Clutch Supply Circuit
249 Ambient Air Temperature Sensor Circuit
254 Fuel Shutoff Valve Solenoid Supply Circuit
255 Fuel Shutoff Valve Solenoid Supply Circuit
256 Ambient Air Temperature Sensor Circuit
259 Fuel Shutoff Valve
284 Sensor Supply Voltage
285 J1939 Datalink Multiplexing
286 J1939 Datalink Multiplexing
293 OEM Temperature Sensor Circuit
294 OEM Temperature Sensor Circuit
295 Ambient Air Pressure Sensor
297 OEM Pressure Sensor Circuit
298 OEM Pressure Sensor Circuit
319 Real-Time Clock Power Circuit
338 Idle Shutdown Vehicle Accessory/Ignition Bus Relay Circuit
339 Idle Shutdown Vehicle Accessory/Ignition Bus Relay Circuit
341 Unswitched Battery Supply Circuit
343 Electronic Control Module (ECM
349 Auxiliary Speed Governor
352 Sensor Voltage Supply
359 ICON™ Idle Control System
378 Actuator Circuit
379 Actuator Circuit
386 Sensor Voltage Supply
387 Throttle Voltage Supply
388 Engine Brake Supply Circuit
392 Engine Brake Supply Circuit
393 Engine Brake Supply Circuit
394 Actuator Circuit
395 Actuator Circuit
396 Actuator Circuit
397 Actuator Circuit
398 Actuator Circuit
399 Actuator Circuit
415 Actuator Circuit
419 Intake Manifold Pressure Sensor
422 Coolant Level Sensor Circuit
426 J1939 Datalink Communication
428 Water-In-Fuel (WIF Sensor Circuit
429 Water-In-Fuel (WIF Sensor Circuit
431 Idle Validation Switch Choice
431 iss Idle Validation Switch Circuit
431 niss Idle Validation Switch Circuit
431 sss Idle Validation Switch Circuit
432 Accelerator Pedal Circuit
433 Intake Manifold Pressure Circuit
434 Unswitched Battery Supply Circuit
435 Oil Pressure Sensor
441 Unswitched Battery Supply Circuit
442 Unswitched Battery Supply Circuit
443 Throttle Voltage Supply
449 High Fuel Pressure
451 Front Rail Pressure Sensor Circuit
452 Front Rail Pressure Sensor Circuit
465 Wastegate Actuator Number 1 Circuit
466 Wastegate Actuator Number 1 Circuit
469 ICON™ Cab Thermostat Circuit
472 Crankcase Oil Level Sensor Circuit
474 Starter Solenoid Lockout Relay Driver Circuit
475 Electronic Air Compressor Governor Circuit
476 Electronic Air Compressor Governor Circuit
482 Low Fuel Pressure
483 Rear Rail Pressure Sensor Circuit
484 Rear Rail Pressure Sensor Circuit
485 Rear Rail Pressure Sensor Circuit
486 Fuel System Underfueling
489 Auxiliary Speed Input Error
491 Wastegate Actuator Number 2 Circuit
492 Wastegate Actuator Number 2 Circuit
496 Sensor Supply Voltage
527 Switched Output A Error
528 Switched Output B Error
529 Switched Output B Error
536 Autoshift Low Gear Actuator (Lockout Solenoid Circuit
537 Autoshift High Gear Actuator (Shift Solenoid Circuit
538 Autoshift Neutral Actuator
541 ICON™ Starter Relay/Interlock Circuit
544 Top 2 Transmission Circuit - Mechanical System Failure
546 Fuel Pressure Sensor Circuit
547 Fuel Pressure Sensor Circuit
551 Idle Validation Switch Choice
551 iss Idle Validation Switch Circuit
551 ivs Idle Validation Switch Circuit
551 sss Idle Validation Switch Circuit
553 Fuel System Overfueling
559 Fuel System Underfueling
581 Fuel Inlet Restriction Sensor Circuit
582 Fuel Inlet Restriction Sensor Circuit
583 Fuel Inlet Restriction Sensor Circuit
588 Engine Start Alarm Circuit
589 Engine Start Alarm Circuit
595 Turbocharger Speed High (Calculated
596 Voltage Monitor - High Voltage
597 Voltage Monitor - Low Voltage
598 Voltage Monitor - Very Low Voltage
731 Engine Speed Sensor and Camshaft Position Sensor - Mechanical Misalignment Between Camshaft and Crankshaft Sensors
753 Engine Speed Sensor Circuit
755 Fuel Injector
758 Fuel Injector
784 Adaptive Cruise Control Circuit
951 Cylinder Power Imbalance
before October of 2002 (pre-EGR engines).ISM fault codes:
115 Engine Position Sensor
121 Engine Position Sensor
131 Accelerator Pedal Position Sensor Circuit
132 Accelerator Pedal Position Sensor Circuit
133 Remote Accelerator Pedal or Lever Position Sensor Circuit
134 Remote Accelerator Pedal or Lever Position Sensor Circuit
135 Engine Oil Pressure Sensor Circuit
141 Engine Oil Pressure Sensor Circuit
144 Engine Coolant Temperature Sensor Circuit
145 Engine Coolant Temperature Sensor Circuit
147 Frequency Throttle Control
148 Frequency Throttle Control
153 Intake Manifold Air Temperature Sensor Circuit
154 Intake Manifold Air Temperature Sensor Circuit
187 Sensor Supply Voltage
198 ICON™ Lamp
199 ICON™ Lamp
212 Engine Oil Temperature Sensor Circuit
223 Burn Valve Solenoid Fault
227 Sensor Supply Voltage
235 Engine Coolant Level — Engine Protection
237 Multiple Unit Synchronization (soft coupled Marine
254 Fuel Shutoff Solenoid Supply Circuit
255 Fuel Shutoff Solenoid Supply Circuit
285 SAE J1939 Data Link Multiplexing
286 SAE J1939 Data Link Multiplexing
311 Injector Circuit
312 Injector Circuit
313 Injector Circuit
314 Injector Circuit
315 Injector Circuit
319 Real Time Clock Power Circuit
321 Injector Circuit
322 Injector Circuit
323 Injector Circuit
324 Injector Circuit
325 Injector Circuit
331 Injector Circuit
332 Injector Circuit
338 Ignition Bus Relay Circuit
339 Ignition Bus Relay Circuit
349 Auxilliary Speed Governor Circuit
359 ICON™ Engine Auto Start Failure
387 Accelerator Pedal Voltage Supply
426 SAE J1939 Data Link Communication
428 Water In Fuel (WIF Sensor Circuit
429 Water In Fuel (WIF Sensor Circuit
431iss Idle Validation Switch Circuit - Integrated Switch and Sensor Type
431niss Idle Validation Switch Circuit - Non-Integrated Switch and Sensor Type
431sss Idle Validation Switch Circuit - Solid State Switch and Sensor Type
433 Intake Manifold Pressure Sensor Circuit
443 Accelerator Pedal Voltage Supply
465 Wastegate Actuator No. 1 Circuit
466 Wastegate Actuator No. 1 Circuit
489 Auxilliary Speed Input Error
491 Wastegate Actuator No. 2 Circuit
492 Wastegate Actuator No. 2 Circuit
529 Switched Output C Error
537 Autoshift High Gear Actuator (Lockout Solenoid
541 ICON™ Starter Relay Input Circuit
544 Top 2 Transmission Circuit — Mechanical System Failure
551iss Idle Validation Switch Circuit - Integrated Switch and Sensor Type
551ivs Idle Validation Switch Circuit - Non-Integrated Switch and Sensor Type
551sss Idle Validation Switch Circuit - Solid State Switch and Sensor Type
588 ICON™ Starter Relay Input Circuit
596 Voltage Monitor — High Voltage
597 Voltage Monitor — Low Voltage
598 Battery Voltage Monitor — Very Low Voltage
2291 Vehicle Speed Sensor Circuit
