Начать новую тему Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней.  [ 1 сообщение ]
Коды ошибок двигателей Caterpillar 3126
Сообщение Коды ошибок двигателей Caterpillar 3126
CATERPILLAR
ENGINE FAULT CODE REFERENCE
In the center of the tachometer is a rectangular display that will illuminate a fault code whenever your engine is operating with a monitored fault. You should immediately record this fault code and contact your local Cat Dealer for assistance. By properly reporting this code to your service provider, you will improve the engine service life and reduce any potential downtime of your machine.
DIAGNOSTIC, EVENT, AND FLASH CODES
DESCRIPTION_____________________________________FLASH CODE__________ Fault Code (SPN/FMI)
Coolant Level Sensor Fault_______________________________12________________________________
Fuel Temperature Sensor Open/Short to +Batt.______________13_________________174-03__________
Fuel Temperature Sensor Short to –Batt.___________________13_________________174-03__________
Injector Actuation Pressure Sensor Loss of Signal____________15_________________164-02__________
Injector Actuation Pressure Open/Short to +Batt._____________15________________ 164-03__________
Injector Actuation Pressure Open/Short to – Batt_____________15________________164-04___________
High Injector Actuation Pressure__________________________ 17________________164-00___________
Injector Actuation Control Valve Open/Short_________________18_________________________________
+5 Volt Supply Open/Short to +Batt._______________________ 21________________ 620-03___________
+5 Volt Supply Short to –Batt.____________________________21_________________620-04___________
Digital Sensor Supply Open/Short to +Batt._________________21_________________678-03___________
Digital Sensor Supply Short to –Batt.______________________21_________________678-04___________
+8 Volt Supply Above Normal____________________________21__________________________________
Engine Oil Pressure Sensor Open/Short to +Batt.____________24_________________100-03___________
Engine Oil Pressure Sensor Short to –Batt._________________24_________________100-04___________
Turbocharger Pressure Above Normal_____________________25_________________102-00___________
Turbocharger Outlet Sensor Open/Short to +Batt.___________25_________________ 102-03___________
Turbocharger Outlet Sensor Short to –Batt.________________25__________________102-04___________
Atmospheric Pressure Open/Short to +Batt._______________26__________________108-03____________
Atmospheric Pressure Short to –Batt.____________________26__________________108-04____________
Engine Coolant Temperature Open/Short to +Batt._________27___________________110-03____________
Engine Coolant Temperature Short to –Batt.______________27___________________110-04____________
Throttle Sensor Calibration Required____________________28___________________91-13_____________
Throttle Signal Abnormal_____________________________32___________________91-08_____________
Speed Timing Sensor Loss of Signal____________________34___________________190-02____________
Speed Timing Sensor Mechanical Failure________________34___________________190-11____________
Loss of Secondary Speed Timing Signal_________________34___________________723-02____________
Secondary Speed Timing Sensor Mechanical Failure_______34___________________723-11____________
Engine Overspeed Warning___________________________35___________________0190-00____________
Engine Overspeed Shutdown__________________________35__________________ 0190-16____________
Fuel Pressure Sensor Open/Short to +Batt.______________37___________________94-03______________
Fuel Pressure Sensor Short to –Batt.___________________37___________________94-04______________
Intake Manifold Air Temperature Open/Short to +Batt._____38___________________172-03_____________
Intake Manifold Air Temperature Short to –Batt.__________38___________________172-04_____________
Injector Actuation Press Sensor Mechanical Failure_______39___________________164-11_____________
Engine Timing Calibration___________________________42____________________228-13_____________
Check Timing Sensor Calibration_____________________42_______________________________________
Low Engine Oil Pressure Shutdown___________________46____________________0100-01____________
Low Engine Oil Pressure Warning_____________________46____________________0100-17____________
Low Engine Oil Pressure Derate______________________46____________________0100-18____________
Intake Air Heater Open Circuit_______________________49_______________________________________
Intake Air Heater Short Circuit_______________________49_______________________________________
Intermittent Battery________________________________51____________________168-02______________
Electronic Control Module Error______________________53_______________________________________
Check Customer or System Parameters_______________56_____________________1111-02_____________
Personality Module Mismatch_______________________56_____________________234-02_______________
J1939 Data Link Communication_____________________58_____________________639-09_______________
Incorrect Engine Software__________________________59_________________________________________
High Engine Coolant Temp. Shutdown________________61_____________________0110-00_______________
High Engine Coolant Temp. Warning__________________61_____________________0110-15_______________
High Engine Coolant Temp. Derate___________________61_____________________0110-16________________
Low Engine Coolant Level Shutdown_________________62_____________________0111-01_________________
Low Engine Coolant Level Warning__________________62_____________________0111-17_________________
Low Engine Coolant Level Derate___________________62_____________________0111-18__________________
Fuel Filter Restriction Warning_____________________63_____________________0094-00__________________
High Fuel Pressure Warning_______________________63_____________________0094-00__________________
Fuel Filter Restriction Derate______________________63_____________________0094-15__________________
Fuel Filter Restriction Shutdown___________________63_____________________0094-16___________________
High Inlet Air Temperature Warning________________64_____________________0172-15___________________
High Inlet Air Temperature Derate_________________64_____________________0172-16____________________
High Fuel Temp. Shutdown_______________________65_____________________0174-00____________________
High Fuel Temp. Warning________________________65_____________________0174-15____________________
High Fuel Temp. Derate_________________________65_____________________0174-16_____________________
Cylinder 1 Fault_______________________________72_____________________651-11______________________
Cylinder 2 Fault_______________________________72_____________________652-11______________________
Cylinder 3 Fault_______________________________73_____________________653-11______________________
Cylinder 4 Fault_______________________________73_____________________654-11______________________
Cylinder 5 Fault_______________________________74_____________________655-11______________________
Cylinder 6 Fault_______________________________74_____________________656-11______________________
High Auxiliary Pressure Shutdown________________NA_____________________1387-00_____________________
Low Auxiliary Pressure Shutdown________________NA_____________________1387-01_____________________
High Auxiliary Pressure Warning_________________NA_____________________1387-15_____________________
High Auxiliary Pressure Derate__________________NA______________________1387-16_____________________
Low Auxiliary Pressure Warning_________________NA______________________1387-17_____________________
Low Auxiliary Pressure Derate__________________NA______________________1387-18______________________
High Auxiliary Temperature Shutdown____________NA______________________441-00_______________________
Low Auxiliary Temperature Shutdown____________NA______________________441-01_______________________
High Auxiliary Temperature Warning_____________NA______________________441-15_______________________
High Auxiliary Temperature Derate______________NA_______________________441-16_______________________
Low Auxiliary Temperature Warning_____________NA_______________________441-17_______________________
Low Auxiliary Temperature Derate______________NA_______________________441-18________________________
Ether Start Relay Open/Short to +Batt.____________________________________545-05________________________
Ether Start Relay Short to –Batt._________________________________________545-06________________________
J1939CODES-03
Feb 10, 2003
3126 Fault codes.doc [90 Кб]
14 апр 2011 10:00
