Build Date 5/13/2004
AXLE, FRONT NON-DRIVING {DANA SPICER E-1202W} Wide Track, I-Beam Type, 12,000-lb Capacity
AXLE, REAR, TANDEM {DANA SPICER DS404/RS404} Single Reduction 40,000-lb Capacity; 200 Wheel Ends
Gear Ratio 3.70
TRANSMISSION, MANUAL {FULLER FRO-14210B} 10-Speed Manual, With Overdrive, With Air Shift
ENGINE, DIESEL {CATERPILLAR C13 ACERT} EPA 04, 380 HP ГАВ 2100 RPM, 1450 lb-ft Torque ГАВ 1200 RPM, 2100 RPM Governed Speed; 395 Peak HP (Max) and With Electronic Controls
Eng Srl Number 0KCB10083
