В том документе что привели на 71 страничке.
The Eaton VORAD EVT–300 Collision Warning
System (CWS) is intended solely as an aid for an
alert and conscientious professional driver. It is
not intended to be used or relied upon to operate
a vehicle. Use the system in conjunction with
rearview mirrors and other instrumentation to
safely operate the vehicle. Operate this vehicle,
equipped with the EVT–300 Collision Warning
System (and optional SmartCruise), in the same
safe manner as if the EVT–300 Collision Warning
System were not present.
The EVT–300 Collision Warning System is not a
substitute for safe, normal driving procedures,
nor will it compensate for any driver impairment
such as drugs, alcohol, or fatigue.
The EVT–300 Collision Warning System may provide
little or no warning of hazards such as pedestrians,
animals, oncoming vehicles, or cross
traffic.
On vehicles with SmartCruise, the vehicle will not
deactivate cruise control for stationary targets,
such as a car stopped in your traveling lane.
Failure to drive safely and use the system properly
could result in personal injury and/or death
and severe property damage.
Dash Switches
The following dash switches (Fig. 2.77) are used to
control the CWS and optional SmartCruise.
· Headway Alert (HDWY ALERT): This switch
turns on the CWS. On most systems, the CWS
will turn on automatically when the ignition is
turned on. The switch is backlit by a green light
that indicates the system is on.
If the system is equipped with the optional
SmartCruise, the switch will not be installed.
· Headway Control (HDWY CNTL): This switch
is installed on vehicles with the optional Smart-
Cruise. When this switch is pressed the light
comes on to indicated that the vehicle is in
SmartCruise mode. It has the same function as
the SPD CNTL switch, which will be installed
on vehicles without SmartCruise. The switch
will be backlit by a green light when the Headway
Control is on.
· Resume/Accelerate - Set/Coast (RSM/ACC -
SET/CST): This switch works the same as it
does on conventional cruise control. On vehicles
with SmartCruise, the speed will change
if necessary to maintain the set headway.
· Headway Volume (HDWY VOL+/-): This
switch adjusts the volume of the headway
alerts and other audible alerts from the CWS.
The speaker volume will reset to maximum volume
when the system is turned off and back
on again, or the ignition is turned off and back
on
