Приветствую! подскажите комплектацию по агрегатам VIN HSRKCARONH430689. и если возможно характеристику мотора. зарание спасибо!
24 май 2013 16:08
Александр_GW
Re: запрос по интеру
Build Date 1/6/1992 Model CO9700 6X4 SBA Wheel Base 141.7 in Gear Ratio 3.73 ENGINE, DIESEL {CUMMINS N14-330E CELECT} 50 State 330 HP 1600 RPM; 1800 RPM Governed Speed; 1350 lb-ft Torque 1100 RPM TRANSMISSION, MANUAL {MERITOR RMX9-145B} 9-Speed Manual; with Overdrive, With Air Shift and Aluminum Clutch Housing AXLE, FRONT NON-DRIVING {INTERNATIONAL I-120SG} I-Beam Type, 12,000-lb Capacity AXLE, REAR, TANDEM {MERITOR RT-40-145} Single Reduction 40,000-lb Capacity 200 Wheel Ends
Build Date 9/16/1988 Model 9300 6X4 SBA Wheel Base 202.8 in Gear Ratio 4.10 ENGINE, DIESEL {CUMMINS Formula 315 88NT} 50-State, 315 HP ГАВ 1800 RPM, 1150 lb-ft Torque ГАВ 1300 RPM TRANSMISSION, MANUAL {FULLER RTX-12609B} 9-Speed Manual with Overdrive, and With Air Shift. AXLE, FRONT NON-DRIVING {SPICER I-120} 12,000-lb Capacity AXLE, REAR, TANDEM {DANA SPICER J400-S} Single Reduction, 40,000-lb Capacity, With 200 Wheel Ends
Build Date 4/27/1993 Model CO9700 6X4 SBA Wheel Base 141.7 in Gear Ratio 3.73 ENGINE, DIESEL {CUMMINS N14-330E CELECT} 50 State 330 HP ГАВ 1600 RPM; 1800 RPM Governed Speed; 1350 lb-ft Torque ГАВ 1100 RPM TRANSMISSION, MANUAL {MERITOR RMX9-145B} 9-Speed Manual; with Overdrive, With Air Shift and Aluminum Clutch Housing AXLE, FRONT NON-DRIVING {MERITOR FF-961} I-Beam Type, 12,000-lb Capacity AXLE, REAR, TANDEM {MERITOR RT-40-140} Single Reduction 40,000-lb Capacity With 200 Wheel Ends
Build Date 8/19/1988 Model CO-9600 6X4 Wheel Base 155.5 in Gear Ratio 3.91 ENGINE, DIESEL {CATERPILLAR 3406} 49 State 350 HP ГАВ 1800 RPM, 1350 lb-ft Torque ГАВ 1100 RPM (High Torque) TRANSMISSION, MANUAL {FULLER RTX-14609P} 9-Speed Manual; With Overdrive and With Air Shift AXLE, FRONT NON-DRIVING {SPICER I-120} 12,000-lb Capacity AXLE, REAR, TANDEM {DANA SPICER J400-S} Single Reduction, 40,000-lb Capacity
Build Date 9/8/1998 Model 9800 SFA 6X4 Wheel Base 177.2 in Gear Ratio 4.11 ENGINE, DIESEL {CUMMINS M11-370 ESP PLUS} 50 State 370/410 HP ГАВ 1800 RPM Governed Speed; 1350 to 1450 lb-ft Torque ГАВ 1200 RPM; 410 Peak HP (Max) TRANSMISSION, MANUAL {FULLER RTX-14710B} 10-Speed Manual; With Overdrive and with Air Shift AXLE, FRONT NON-DRIVING {INTERNATIONAL I-120SG} I-Beam Type, 12,000-lb Capacity SUSPENSION, REAR, AIR, TANDEM {INTERNATIONAL } 52" Axle Spacing; 40,000-lb Capacity, 9.500" Ride height, With Shock Absorbers
Build Date 10/13/1987 Model CO-9600 6X4 Wheel Base 157.5 in / 400.0 cm Gear Ratio 3.90 ENGINE, DIESEL {CUMMINS Formula 350 88NT} 50-State 350 HP ГАВ 1800 RPM, 1200 lb-ft Torque ГАВ 1300 RPM TRANSMISSION, MANUAL {FULLER RTX-12609P} 9-Speed Manual with Overdrive and With Air Shift AXLE, FRONT NON-DRIVING {SPICER I-120} 12,000-lb Capacity AXLE, REAR, TANDEM {MERITOR SQ-100P} Single Reduction, 40,000-lb Capacity, With Lube Oil Pump and 200 Wheel Ends SUSPENSION, REAR, AIR, TANDEM {INTERNATIONAL } 52" Axle Spacing; 40,000-lb Capacity, 9.500" Ride height, With Shock Absorbers
потянуло меня на старину. привет ГУДВИЛУ. выбираю себе интер 9700 пробейте VIN---1HSRKCTR1NH400825 такое ощущение что двигатель не родной---11629228. интересует комплектация---какой двигатель , кпп , мосты. спасибо.
Build Date 7/29/1991 ENGINE, DIESEL {CUMMINS N14-330 STC} 50 State 330 HP ГАВ 1600 RPM; 1700 RPM Governed Speed; 1350 lb-ft Torque ГАВ 1100 RPM Eng Srl Number 011629228 TRANSMISSION, MANUAL {FULLER RTX-14709H} 9-Speed Manual; with Overdrive and with Air Shift AXLE, FRONT NON-DRIVING {INTERNATIONAL I-120SG} I-Beam Type, 12,000-lb Capacity AXLE, REAR, TANDEM {MERITOR SQ-100} Single Reduction, 40,000-lb Capacity Less Lube Oil Pump and With 200 Wheel Ends
Продана в TRANSPORT AMERICA https://www.transportamerica.com/ Build Date 8/19/1993 ENGINE, DIESEL {CATERPILLAR 3406 PEEC} 50 State 330 HP ГАВ 1800 RPM, 1350 lb-ft Torque ГАВ 1100 RPM Eng Srl Number A4CK18569 TRANSMISSION, MANUAL {FULLER RTX-14710B} 10-Speed Manual; With Overdrive and with Air Shift AXLE, FRONT NON-DRIVING {MERITOR FF-942} I-Beam Type, 13,200-lb Capacity AXLE, REAR, TANDEM {MERITOR RT-40-140} Single Reduction 40,000-lb Capacity With 200 Wheel Ends Gear Ratio 3.91
Build Date 3/29/1993 ENGINE, DIESEL {CUMMINS N14-330E CELECT} 50 State 330 HP ГАВ 1600 RPM; 1800 RPM Governed Speed; 1350 lb-ft Torque ГАВ 1100 RPM Eng Srl Number S11685569 TRANSMISSION, MANUAL {MERITOR RMX9-145B} 9-Speed Manual; with Overdrive, With Air Shift and Aluminum Clutch Housing AXLE, FRONT NON-DRIVING {MERITOR FF-961} I-Beam Type, 12,000-lb Capacity AXLE, REAR, TANDEM {MERITOR RT-40-140} Single Reduction 40,000-lb Capacity With 200 Wheel Ends Gear Ratio 3.73
22 апр 2016 07:44
mixey1985
Автомобиль/VIN: 2HSCNAPR04C089082
Здравствуйте. Пожалуйста дайте данные по машине интер 2HSCNAPR04C089082 особенно интересуют коробка, мосты и редуктора.
15 май 2016 05:15
Александр_GW
Build Date 7/31/2003 ENGINE, DIESEL {CUMMINS ISX 435 ST} 435 HP ГАВ 1800 RPM Electronic Feature Default Speed (Actual 2000 RPM Governed Speed); 1450/1650 lb-ft Torque ГАВ 1200 RPM; 455 Peak HP (Max) Eng Srl Number 079016435 КПП: TRANSMISSION, MANUAL {MERITOR M-14G10A-M16 Torq-2} 10-Speed Manual; With Electric Over Air Shift Control, With Aluminum Clutch Housing and Internal Lube Oil Pump Передний мост: AXLE, FRONT NON-DRIVING {MERITOR MFS-12-143D} I-Beam Type, With Integrated Hub; Wide Track, 12,000-lb Capacity Задние мосты: AXLE, REAR, TANDEM {MERITOR RT-40-145} Single Reduction 40,000-lb Capacity 200 Wheel Ends Gear Ratio 2.64
Здравствуйте! Интересует VIN 2HSFMAMR9YCO49058. Мощность дв? Модель кпп? Передатка в мостах? Ширина задних колодок и др. заранее спасибо!
03 июл 2016 07:53
Александр_GW
Добрый день!
Можем только общий спек пробить ENGINE, DIESEL {DETROIT DIESEL Series 60 - 12.7L} 50 State 430/470 HP ГАВ 1800 RPM, 1550 lb-ft Torque ГАВ 1200 RPM, Cruise Power, 1800 RPM Governed Speed TRANSMISSION, MANUAL {FULLER RTLO-16610B-T2} Super 10 Top 2; 10-Speed Manual; With Overdrive; (Top Two Gears Shift Automatically); With Air Shift and Integral Lube Oil Pump; 1650 lb-ft Torque Rating Gear Ratio 3.73 AXLE, REAR, TANDEM {MERITOR RT-40-145} Single Reduction 40,000-lb Capacity 200 Wheel Ends
