Зарегистрирован: 05 апр 2005 12:37 Сообщения: 354 Откуда: Санкт-Петербург
CATERPILLAR ACERT ENGINE DIAGNOSTIC CODES
This group provides information on the engine fault codes that could potentially appear on the LCD display at the center of your electronic dash when using the Engine Diagnostics Menu feature. Refer to Chapter 59-104 in your service or operator manual for instructions on reading and clearing fault codes. These codes can be used to help isolate the problem area in your engine. Refer to the appropriate Caterpillar Troubleshooting Manual or contact your Caterpillar dealer for additional information on isolating and repairing potential or existing problems.
J1939 SPN J1939 FMI DIAGNOSTIC CODE DESCRIPTION FLASH CODE 651 1-05 CYLINDER #1 INJECTOR CURRENT LOW 72 651 1-06 CYLINDER #1 INJECTOR CURRENT HIGH 72 652 2-05 CYLINDER #2 INJECTOR CURRENT LOW 72 652 2-05 CYLINDER #2 INJECTOR CURRENT HIGH 72 653 3-05 CYLINDER #3 INJECTOR CURRENT LOW 73 653 3-06 CYLINDER #3 INJECTOR CURRENT HIGH 73 654 4-05 CYLINDER #4 INJECTOR CURRENT LOW 73 654 4-06 CYLINDER #4 INJECTOR CURRENT HIGH 73 655 5-05 CYLINDER #5 INJECTOR CURRENT LOW 74 655 5-06 CYLINDER #5 INJECTOR CURRENT HIGH 74 656 6-05 CYLINDER #6 INJECTOR CURRENT LOW 74 656 6-06 CYLINDER #6 INJECTOR CURRENT HIGH 74 637 22-11 PRIMARY TO SECONDARY ENGINE SPEED SIGNAL CALIBRATION 42 637 22-13 ENGINE SPEED SIGNAL CALIBRATION NOT PERFORMED 42 644 30-08 PTO THROTTLE SIGNAL INVALID 29 644 30-13 PTO THROTTLE SIGNAL CALIBRATION 29 678 41-03 8 VOLT SUPPLY ABOVE NORMAL 21 678 41-04 8 VOLT SUPPLY BELOW NORMAL 21 158 43-02 IGNITION KEY SWITCH FAULT 71 XX 52-11 INLET AIR SHUTOFF SHUTDOWN 00 706 54-05 AUXILIARY OUTPUT #06 CURRENT LOW 66
J1939 SPN J1939 FMI DIAGNOSTIC CODE DESCRIPTION FLASH CODE 706 54-06 AUXILIARY OUTPUT #06 CURRENT HIGH 66 707 55-05 AUXILIARY OUTPUT #07 CURRENT LOW 67 707 55-06 AUXILIARY OUTPUT #07 CURRENT HIGH 67 723 64-02 LOSS OF SECONDARY ENGINE SPEED SIGNAL 34 592 71-00 IDLE SHUTDOWN OVERRIDE 01 592 71-01 IDLE SHUTDOWN OCCURRENCE 47 592 71-14 PTO SHUTDOWN OCCURRENCE 47 84 84-00 WHEEL-BASED VEHICLE OVERSPEED WARNING 41 84 84-01 LOSS OF WHEEL-BASED VEHICLE SPEED SIGNAL 31 84 84-02 INVALID WHEEL-BASED VEHICLE SPEED SIGNAL 36 84 84-08 WHEEL BASED VEHICLE SPEED OUT OF RANGE 36 84 84-10 WHEEL BASED VEHICLE SPEED RATE OF CHANGE 36 84 84-14 QUICKSTOP OCCURRENCE 00 91 91-08 ACCELERATOR PEDAL POSITION INVALID 32 91 91-13 ACCELERATOR PEDAL POSITION OUT OF CALIBRATION 28 100-01 100-01 LOW OIL PRESSURE WARNING 46 100-03 100-03 OIL PRESSURE SENSOR VOLTAGE HIGH 24 100-04 100-04 OIL PRESSURE SENSOR VOLTAGE LOW 24 100-11 100-11 VERY LOW OIL PRESSURE 46 102-03 102-03 BOOST PRESSURE SENSOR VOLTAGE HIGH 25 102-04 102-04 BOOST PRESSURE SENSOR VOLTAGE LOW 25 102-07 102-07 BOOST PRESSURE NOT RESPONDING 25 105-00 105-00 HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING 64 105-03 105-03 INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE HIGH 38 105-04 105-04 INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE LOW 38
J1939 SPN J1939 FMI DIAGNOSTIC CODE DESCRIPTION FLASH CODE 105-11 105-11 VERY HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING 64 108-03 108-03 BAROMETRIC PRESSURE VOLTAGE HIGH 26 108-04 108-04 BAROMETRIC PRESSURE VOLTAGE LOW 26 108-10 108-10 BAROMETRIC PRESSURE SIGNAL RATE OF CHANGE 26 110-00 110-00 HIGH COOLANT TEMPERATURE WARNING 61 110-03 110-03 COOLANT TEMPERATURE SENSOR VOLTAGE HIGH 27 110-04 110-04 COOLANT TEMPERATURE SENSOR VOLTAGE LOW 27 110-11 110-11 VERY HIGH COOLANT TEMPERATURE 61 111-01 111-01 LOW COOLANT LEVEL WARNING 62 111-02 111-02 INVALID COOLANT LEVEL 12 111-03 111-03 COOLANT LEVEL SENSOR VOLTAGE HIGH 12 111-04 111-04 COOLANT LEVEL SENSOR VOLTAGE LOW 12 111-11 111-11 VERY LOW COOLANT LEVEL 62 111-14 111-14 LOW COOLANT LEVEL WARNING (LESS THAN 6 ENGINE HOURS) 62 1072-05 121-05 RETARDER SOLENOID LOW/HIGH VOLTAGE LOW 14 1072-06 121-06 RETARDER SOLENOID LOW/HIGH VOLTAGE HIGH 14 1073-05 122-05 RETARDER SOLENOID MED/HIGH VOLTAGE LOW 14 1073-06 122-06 RETARDER SOLENOID MED/HIGH VOLTAGE HIGH 14 XX 166-04 RATED ENGINE POWER SPECIAL INSTRUCTIONS 00 168-02 168-02 INTERMITTENT BATTERY POWER TO THE ECM 51 171-03 171-03 OUTSIDE AIR TEMP SENSOR VOLTAGE HIGH 00 171-04 171-04 OUTSIDE AIR TEMP SENSOR VOLTAGE LOW 00 171 171-11 NO OUTSIDE AIR TEMP DATA 00 174 174-00 HIGH FUEL TEMP WARNING 65
J1939 SPN J1939 FMI DIAGNOSTIC CODE DESCRIPTION FLASH CODE 174-03 174-03 FUEL TEMP VOLTAGE HIGH 13 174-04 174-04 FUEL TEMP VOLTAGE LOW 13 190 190-00 ENGINE OVERSPEED WARNING 35 190 190-08 PRIMARY ENGINE SPEED LOSS OF SIGNAL 34 XX 191-07 TRANSMISSION NOT RESPONDING 68 XX 224-11 THEFT DETERRENT ENABLED 00 639 231-02 J1939 DEVICE SENDING INCORRECT DATA 00 639 231-12 J1939 DEVICE NOT RESPONDING 00 620 232-03 5 VOLT SUPPLY ABOVE NORMAL 21 620 232-04 5 VOLT SUPPLY ABOVE NORMAL 21 597 246-11 BRAKE PEDAL SWITCH #1 FAULT 00 603 247-11 BRAKE PEDAL SWITCH #2 FAULT 00 631 252-11 ENGINE SOFTWARE INCORRECT 59 630 253-02 CHECK CUSTOMER OR SYSTEM PARAMETERS 56 XX 253-11 CHECK TRANSMISSION CUSTOMER PARAMETERS 56 2949-05 283-05 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT LOW 97 2949-06 283-06 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT HIGH 97 2949-07 283-07 INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE NOT RESPONDING 97 2988-05 284-05 ENGINE COOLANT DIVERTER SOLENOID CURRENT LOW 98 2988-06 284-06 ENGINE COOLANT DIVERTER SOLENOID CURRENT HIGH 98 2950-05 285-05 INTAKE VALVE ACTUATOR #1 CURRENT LOW 92 2950-06 285-06 INTAKE VALVE ACTUATOR #1 CURRENT HIGH 92 2950-07 285-07 INTAKE VALVE ACTUATOR #1 NOT RESPONDING 92 2951-05 286-05 INTAKE VALVE ACTUATOR #2 CURRENT LOW 92
2951-06 286-06 INTAKE VALVE ACTUATOR #2 CURRENT HIGH 92 2951-07 286-07 INTAKE VALVE ACTUATOR #2 NOT RESPONDING 92 2952-05 287-05 INTAKE VALVE ACTUATOR #3 CURRENT LOW 93 2952-06 287-06 INTAKE VALVE ACTUATOR #3 CURRENT HIGH 93 2952-07 287-07 INTAKE VALVE ACTUATOR #3 CURRENT NOT RESPONDING 93 2953-05 288-05 INTAKE VALVE ACTUATOR #4 CURRENT LOW 93 2953-06 288-06 INTAKE VALVE ACTUATOR #4 CURRENT HIGH 93 2953-07 288-07 INTAKE VALVE ACTUATOR #4 CURRENT NOT RESPONDING 93 2954-05 289-05 INTAKE VALVE ACTUATOR #5 CURRENT LOW 94 2954-06 289-06 INTAKE VALVE ACTUATOR #5 CURRENT HIGH 94 2954-07 289-07 INTAKE VALVE ACTUATOR #5 CURRENT NOT RESPONDING 94 2955-05 290-05 INTAKE VALVE ACTUATOR #6 CURRENT LOW 95 2955-06 290-06 INTAKE VALVE ACTUATOR #6 CURRENT HIGH 95 2955-07 290-07 INTAKE VALVE ACTUATOR #6 CURRENT NOT RESPONDING 95 2948-01 385-01 LOW INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE 95 2948-03 385-03 INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE HIGH 95 2948-04 385-04 INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE LOW 95
